You must enable EAP globally.
The RADIUS server uses the secret key to validate users.
Add an EAP RADIUS server:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#radius server host fe80:0:0:0:21b:4fff:fe5e:73fd key radiustest used-by eapol enable
The following table defines parameters for the radius server host command.
Variable |
Value |
acct-enable |
Enables accounting for the server. |
acct-port <1-65536> |
Specifies the accounting port. The default is 1813. |
enable |
Enables the RADIUS server host. |
host WORD<0–113> |
Configures a host server. WORD<0–113> specifies the IPv4 address, IPv6 address, or fully qualified domain name (FQDN). If you use an FQDN, you must also configure the switch to use DNS. |
key WORD<0-32> |
Specifies the secret key. |
port <1-65535> |
Specifies the port ID number. The default is 1812. |
priority <1-10> |
Specifies the priority. The lowest number is the highest priority. The default is 10. |
retry <0-6> |
Specifies the retry count. The default is 1. |
secure-enable |
Enables secure mode on the server. The default is disabled. |
secure-log-level <critical | debug | error | info | warning> |
Specifies the RADIUS secure server log severity level. The default is error. |
secure-mode <dtls | tls> |
Specifies the protocol for establishing the secure connection with the server. The possible values are:
The default is TLS. Important:
To avoid TLS handshake issues if the switch and
RADsec proxy server run different versions of
OpenSSL, manually force TLS version 2 negotiation
through the RADsec proxy by adding the following
text to the radsecproxy.conf configuration file:
tls default{ ... TlsVersion TLS1_2 } |
secure-profile WORD<1-16> |
Specifies the secure profile name. |
timeout <1-180> |
Specifies the timeout of the server. The default is 8. |
